Taking Battery Out to charge
You don't mention Model Year so I can't tell if your vehicle has BMS (Battery Monitoring System) fitted. If so, you may get odd messages or DTC's set but it should recalibrate itself. BMS usually only needs calibration with Jaguar diagnostics after a disconnect and a new battery is fitted.
Well it all went well, no warning messeges at all, just the parking brake and windows needed recalibration, it let me run the car without the auxiliary battery just says eco stop start unavailable, ive now fully charged and fitted the auxiliary battery and the stop start started working.
So case closed, thanks for the help all
I own a 2015 XF 3.9SC AWD which I purchased new and the car now has approximately 18,000 miles on it. I use it every day but only put on about 20 miles per day. Every couple of weeks or so I plug the car into a Battery Tender Plus to bring it up to full charge.
recently had a problem where the Start/Stop function stopped working. I was also under the impression that this feature was controlled by the smaller battery in trunk. When I brought the car into dealer, the service advisor also said that the smaller battery controls the Start/Stop function. I told him that I was not so sure about this.
After about an hour the service advisor called me over to his desk and said that he had apparently given me incorrect information because my small battery tests fine but the larger battery was defective.
They changed the larger battery to an Interstate AGM 900 CCA battery under warranty and I have not had the problem since. This was done a few months ago.
So.....it appears to me that a defective larger battery can cause problems with the start/stop function and I am still not certain what the smaller battery does except to run auxiliary functions when the car is in the STOP position. In your case, I would not rule out a defective larger battery as the culprit.
Yes that's correct.
We need to understand how the system works.
The big battery does all the starting and stopping. The little battery is to power the rest of the car when the engine is off. So if the big battery gets weak then the car will shut off the ECO mode. Same as if the little battery gets weak ECO mode is shut off.
Yes that's correct.
Your theory sounds solid.
I was told a few years ago that the smaller battery was a 16v unit to spin the starter over very fast to get it to fire fast at the light.
Now that we know that the battery is the Exide 151 battery, it is 12v and is way to small to spin the starter over effectively.
66s-type
25
09-17-2016 03:57 AM
orangeblossom
04-19-2016 06:01 AM
Road Racer
03-27-2015 05:00 PM
