Thermostat fixes all!!!
Hey guys..After lots of work done on the cooling system on my XFs/c. New aux coolant pump,s/c coolant pump,new hoses all round(including the bugger under the supercharger),expansion tank and gaskets and ducts i was still getting more heat in the wrong places. I was hesitant to buy new thermostat because i was told i had to buy the housing too. So i just found the thermostat (AJ811788) without housing. Installed it and what do you know she is all better. Well she will be once i have run her a few miles. Did a reset on the battery so off i go to see if all goes back to normal.
Thermostat cost from Jaguar dealership in New Jersey. $90..Little cheaper online but i managed to get it same day so happy to go pick up.
Received 2,626 Likes
Bear in mind that the water outlet containing the thermostat is made of plastic and can only endure a finite number of cold to hot cycles before failing. The thermostat seal can also fail causing a DTC to be set due to coolant bypassing the thermostat.
It's a good idea to replace the water outlet with the thermostat every time the coolant is changed.
Biff Baxter
21
11-19-2019 04:57 PM
deadboy1977
07-04-2011 10:49 AM
Biff Baxter
04-09-2011 07:53 PM
