Things You Didn't Know About XF's and XFR's
Executive is right, The 2012-> XF's offer an "Active Lighting" system as an option. It actually does turn or bend the light in response to turns. Also, they do have an auto dimming feature available for the high beams.
Axil,
Thank you very much! It seems some people were never told to measure twice and cut once.
HEADLIGHTS WITH INTELLIGENCE
Standard bi-function HID xenon headlights are available with Adaptive Technology, directing the beam to bend in the direction of the steering. The Intelligent High Beam option automatically switches between high- and low-beam to adjust to oncoming or preceding traffic. Headlight washers are standard on all models
Did not know -
TPMS does not measure for the correct pressure, it looks for the same rotation per min which would be a function of all tires being within the same +/- 2psi of eachother
Also for those with the RF glove box, temp does not matter, angle does. The sensor broadcasts a low intensity RF cone directly outwards. If you approach it from straight on it will open 99% of the time. From an angle or sliding from the side like you would as a driver and it won't open.
