Tire pressure monitors - tires losing pressure
I have a 2012 xf. Recently the check tire pressure warning has been coming on and each time I have had to add about 2 pounds to each tire to bring them up to 36 pounds. It seems odd that all of the tires would be losing pressure at the same time. I know that on some other current car makes, when you get new tires they service the tpm's by replacing the valve stems. Can the jaguar tpm's be serviced? Do you think that is the problem?
How often are you having to air up?..if it is frequent then go have your tires remounted...When you replace tires, as a general rule, they put in new TPM x-mitter units in each tire as they have batteries and get weak after time...IMO a MY12 tire x-mitters should be good for at least 5 years.
