TODAY when it was raining my tire warning keep going on and the tire indicator keep on switching between all the wheels anyone have this irratic warning. after i parked and restarted the car an hour later all was normal again
Another poster mentioned this association between wet weather and TPMS false signals. Maybe water is getting into a connector. The sensors are right beside the wheels.
Still getting the problem i took adjusted to 34 psi was more ,i read book its getting cold si ill adjust to n36 psi the book said add 2 lbs si ill try it
