Tire Rotation Anyone?
My 2010 XF Premium has the 19" wheels. The owners manual does not call for tire rotation. I asked the dealer and he said: We check at first service (15,000 miles) and if the fronts are worn more than the rear by a certain %, then we recommend rotating them.
Isn't 15,000 miles too late? this is a heavy high performance car. What do you guys recommend, so I can get the most out of these (expensive) tires besides checking tire pressure of course....
I rotate the tires on all my vehicles twice per year due to snow tire changeovers.
This means about every 5,000 miles.
I get perfectly even tire wear on all my cars.
I would rotate tires at least once each year or every 10,000 miles whichever comes first.
If you have staggered tires (different widths or diameters) then you cannot usefully rotate tires. What rotation does is keep tread depth similar on all tires and eliminates the issue of not being able to get two matching tires which you need if you do not rotate. It works best to buy new tires in sets of four identical new tires.
On the XF the rears will wear about twice as fast as the fronts would be my guess.
For fwd vehicles the wear rate differential can be 3 or 4 times as fast for the drive wheels as for the rear wheels due to driving, steering and braking being done by the fronts. For rwd cars the tires on the rear driving wheels usually wear faster.
I know next to nothing about the Jaguar XF, except for the fact that I would love to own one;-)
However I do remember reading somewhere on this Forum that someone was having an electronics problem, with traction control or diff or some such, because of uneven tyre diameters due to wear.
Snag is I only read it in passing, and it didn't fully stick.
Perhaps one of our more knowledgeable members with modern Jaguar experience will be able to fill out?
Well, the front tires do about 80% of the braking as well as steering the car so perhaps the fronts will wear faster. I will never know because I rotate the tires so the wear is even.
Some ABS and traction control systems are sensitive to unequal tire rolling diameter. So is awd due to constant relative rotation of the differentials if one or two tires are markedly larger than the others.
As for the noise issue, the point of frequent rotation is to avoid the tires getting a set wear pattern in the first place.
Dickie_L_J_O
09-13-2015 07:44 AM
