Tire size for XF Portfolio with Sport Pack wheels/tires
Old 08-14-2013 | 08:20 PM
flyjag's Avatar
Default Tire size for XF Portfolio with Sport Pack wheels/tires
My 2012 XF Portfolio came with the Sport Pack Aquila wheels and P-Zero tires which the dealer swapped for the standard Portfolio wheels/tires. The fronts are 245/45/19 and the rears are 275/40/19. Does anyone know if this is correct for the Sport Pack? I'm not complaining as the car handles great. Thanks for any input.
Old 08-14-2013 | 09:02 PM
Executive's Avatar
When you say standard, you mean the Caravelas?
The rears you posted are for 10" wheel, which never came on the XF.
Arturas 19x8.5 - should have same size tires all around (OEM 245/40/19
Caravelas 19x8.5 - should have same size tires all around (OEM 245/40/19
Aquila is same as above I believe.
Old 08-14-2013 | 09:55 PM
flyjag's Avatar
Thanks for your reply. Yes. I did not like the Caravelas as well as the Aquilas. These were swapped from another new XF at the dealership but I don't know if it was a Sport Pack but assume so since it had the Aquila wheels. Do you see any problem with what I have?
Old 08-16-2013 | 11:26 AM
Executive's Avatar
Sounds like you do have the Caravelas on your car with incorrect tire size on the rears. Should have the following in all four corner 245/40/19
Old 08-16-2013 | 04:32 PM
flyjag's Avatar
The wheels are definitely Aquilas. You can see the photos of my car in the Garage. Plan to question my dealer on why the tires are not to spec. Thanks again.
Old 08-16-2013 | 04:47 PM
Executive's Avatar
Misunderstanding on my part. You do have the Aquilas. As far as i know they should be same size all around.
Will check again and get back to you
flyjag (08-16-2013)
Old 09-07-2013 | 10:33 PM
ddanielcigars's Avatar
I own a 2012 XF with a Sport Pkg, and the Aqulias are the correct wheel for the Sport Pkg, but they should be 245/40 19 on all four wheels.
flyjag (09-08-2013)
Old 09-08-2013 | 11:19 AM
flyjag's Avatar
Thanks for the info. I will visit my dealer tomorrow and try to get an explanation why my tires are different sizes from factory specs.
aholbro1
08-05-2021 06:02 AM
smith356
10-07-2015 07:41 PM
Horus
09-18-2015 06:39 AM
chris4579
09-08-2015 05:34 AM
Whitnessmouse
09-04-2015 12:09 PM
Quick Reply: Tire size for XF Portfolio with Sport Pack wheels/tires
