Tires for poor roads
Tires
I currently have 20 inch Michelin Pilot Super Sports on factory rims. Someone had suggested that 19 inch tires can be put on the factory rims, I dont know if thats really possible/advisable. If i stick with factory rims what are the best riding tire? Many have suggested the Continental DWS. Thanks again.
I realize I will have to stick with the 20 inch tires, unless I change the rims out, but I have heard that the Michelin Super Sports are not the most comfortable riding tires for the stock XF rims. Any other tire suggestions without changing the rims out?
Received 3,259 Likes
I don't know of any "comfortable" or "soft riding" tyre in the stock Supercharged sizes (which I think are the same as the XFR and therefore 285/30/20 rear and 255/35/20 front), it's pretty much not possible in those tyre sizes. There is a much wider range of "soft" tyres in the 19" size, say 265/40/19.
There are a very limited number of 19" rims in the correct PCD etc which will fit over the 380 mm front brake calipers, I know all the OEM F-Type 19" rims do but not a helluva lot else and the F-Type ones would be very expensive for a full set in good nick.
