TPMS disable with SDD
Hi.
I know this was asked before but never fully resolved with an answer - there was always just "drive to this guy, he can help you".
I have managed to get a MongoosePro clone working with fully updated version of SDD 160 update 5.
I also have access to the engineering mode of SDD and therefore CCF editor (the full version).
I have updated my car CCF to select "Module not installed" for TPMS module, yet I still get warnings on my dashboard.
Yes, I know these can be helpful, but since previous owner decided to install non-original modules, they constantly spew errors and so I cannot really rely on that.
I am used to monitor my own tire pressures, I am better off without the TPMS.
So my question to those knowledgable: Is there anything else I need to do in SDD to disable the TPMS besides configuring it as not equipped in CCF?
scjordan1969 (11-08-2021)
scjordan1969 (11-09-2021)
CCF is trial and error because almost nobody has it setup, and those that are knowledgeable don't share their methods. If you do write up something, that would be an anomaly.
I took screenshots of my entire CCF and converted to pdf with text recognition.
Searching for TPMS comes up nil. For 'Tire' the first thing below you probably tried already. Then I checked 'monitor', which led me to 'Tyre', the native spelling. Try some of those.
scjordan1969 (11-12-2021)
Thanks. There was also one option somewhere in Instrument display or Info display or something like that with number 3 and it was set to Tire pressure monitoring system.
Meaning it was not a property, it was a value of another property!
I will definitely do the write-up, but right now i'm in the middle of electromobility expo where we present the motorcycles we sell
Just a quick update. So far I tried the one Tire and one Tyre options, set both to disabled. Still doesn't work although now instead of showing the "check pressure" on random wheels, it just shows TPMS system fault.
So I am definitely making a difference. I still think there is another option that disables the system not only from functioning, but also from showing on the dashboard itself.
Problem is in the CCF editor each setting can have multiple values and it is impossible to easily search (full-text search) within all of these values.
scjordan1969 (11-18-2021)
I found another post (although it was about the XKR), I would bet that unfortunatley it applies to the XF as they are similar in their electronics....
"Disabling the TPMS in the CCF requires engineering mode, it's not available to be changed in a normal SDD, the dealers are blocked from doing this as well."
HTH
HTH
The following 3 users liked this post by curlyboi:
