Transmission Faults List - Help
Hi,
My 2008 XF 2.7D is showing up the following faults and descriptions on my iCarsoft LR VII. Is it a case of go visit a transmission specialist now do you think?
P2702 - Transmission friction element C apply time range / performance
P2704 - Transmission friction element E apply time range / performance
P0735 - Gear 5 incorrect ratio
P0729 - Gear 6 incorrect ratio
P0829 - 5-6 shift./ Gear load 5-6.
The car is randomly going into “Restricted Performance” mode and sometimes comes up with “Gearbox Fault” and “DSC Not Available” on the dash display.
I’m in the Manchester area so any help or advice to someone who can help would be massively appreciated.
Thanks everyone.
Thanks everyone.
Received 2,636 Likes
Prior to going any further with diagnostic tests, check the battery voltage across the terminals with a voltmeter. There should be a minimum of 12.6 volts, if not, charge the battery for 8 hours at 2 to 5 amps and retest. If the battery is still not showing 12.6 volts, it must be replaced. A failing or weak battery can cause many electrical 'gremlins' including random DTCs.
Which side of Manchester, the Blue or the Red?
The battery has just been changed and the iCarsoft LR VII has a great check and all is good for the battery and the charging while running. I’ve also checked it with an amp meter across the battery and it’s fine.
les,
im on the North side just out of Manchester so if you’ve got a name I could look up that would be helpful.
Clubsirth1,
i think you’re possibly referring to the gearbox here. It recently had a full fluid change and new filter/sump as a first attempt to resolve it. Then it had the transmission software updated to the latest spec.
Delta66
03-18-2011 08:04 AM
