Transmission issue
Old 04-25-2016, 11:30 AM
nasa25's Avatar
Has anyone ever just did a flush and refill without changing the pan/sleeve. My mechanic threw this idea at me but I'm not sure how I feel about not changing out the filter (built into the pan). I'm assuming most of the value of the transmission service comes from actually swapping out the fluid but not sure if keeping the old filter in would be a bad long term idea.
  #42
Old 04-25-2016, 12:12 PM
DPK's Avatar
DPK
DPK is offline
First..how many miles on the original filter/fluid?..If more than 60K, it is suggested to change the pan/filter too..If it is less, say around 40K, then just do just a flush refill..My dealer suggests the same approach...the magnets in the bottom of the pan hold the metal junk so that won't break free...But, it's the high mileage sludge that might break free during a flush and plug the filter more....All iffy to me
If you can afford it and for peace of mind..I'd do the whole pan/filter deal..Why cut a corner for sake of a few extra bucks, is all I'm saying.
  #43
Old 04-25-2016, 12:24 PM
nasa25's Avatar
131k km. So around 80k miles. I feel the same way. Plus I want my mechanic to inspect the pan and make sure there isn't a ton of metal shavings floating around in there before he blows the old fluid out of the torque converter.
Thanks for the input.
  #44
Old 04-25-2016, 03:57 PM
Bigg Will's Avatar
Honestly if you do have sludge in your trans, your trans is already on its way out. The same holds true with excessive metal. I never do flushes only fluid exchanges (NO CHEMICALS OTHER THAN NEW TRANS FLUID IS USED), then I change the pan filter and refill. Magnets will pick up the steel and iron, but not the brass, aluminum or clutch material that is also present in your used trans fluid .Please note the quote highlighted in red below. Trans fluid is mostly detergents and anti foaming agents, so it accomplices great cleaning on its own, it's the dirt suspended in that trans fluid you want out.
nasa25 (04-26-2016)
  #45
Old 04-26-2016, 03:12 PM
Spider85's Avatar
nasa25 do not save money on important things on your Jag
  #46
Old 04-29-2016, 07:03 AM
nasa25's Avatar
I agree. I'll be having my shop do a full flush and refill including replacing the pan/filter and sleeve.
  #47
Old 05-11-2016, 01:29 PM
Spider85's Avatar
Not good guys, gave back my car for a repair, they changed oil and pan, they drove a several miles and rang me that the car now jerks and has a problem with changing gears starting from 1-2, the took it back on Monday to the garage, tomorrow should be an answer. I am without a car since 23th April
If they refuse to repair I will go to small court, I am loosing my patience
  #48
Old 05-13-2016, 04:30 AM
Bigg Will's Avatar
A gear range selector on its way out can cause similar issues.
  #49
Old 05-13-2016, 11:33 AM
Spider85's Avatar
But why after oil change it got worse?
Spoke to them today, they said there is no faults on the gearbox, but problem exists, Monday they will strip down gearbox, fantastic
  #50
Old 05-13-2016, 12:31 PM
jagwower's Avatar
Did they use a vacuum and/or pressure system to flush your trans? Or just let it gravity drain?
  #51
Old 05-13-2016, 02:24 PM
Spider85's Avatar
I don't know to be honest
  #52
Old 05-13-2016, 02:52 PM
Bigg Will's Avatar
True, just one of the problems I'd look at based on your issues.
  #53
Old 05-13-2016, 04:50 PM
Madart's Avatar
If you're suggesting that they didn't do the drain properly and then overfilled the tranny I'd be suspicious of this too especially seeing it's developed a hard shift AFTER the work they've done where it was slipping beforehand.
I'm not sure I'd want these guys stripping my transmission.
  #54
Old 05-14-2016, 06:03 AM
Spider85's Avatar
It is an independent Jaguar garage, they should know what they are doing (hopefully), at least I do not pay for this repair
  #55
Old 05-16-2016, 10:59 AM
Bigg Will's Avatar
I did a drain and fill without changing the sleeve.
nasa25 (05-18-2016)
nasa25
06-13-2024 01:34 PM
newbee
03-08-2016 01:14 PM
matade
03-07-2016 07:11 PM
timfountain
03-03-2016 08:32 PM
Mihai Gherghina
03-03-2016 02:15 PM
Quick Reply: Transmission issue
