Trickle charger
Trickle charger
Hi extended Jag family, I read a recent post on properly jump starting a Jag and it got me wondering if there is anything special that needs to do when hooking up a trickle charger. I just wanted to make sure before moving foreword, woke up to 11 inches of new snow this morning so it doesn't look like the cat will be back on the road for a while. Thank in advance for helping me answer what is probably a silly question
Russ
2010 XF S/C
Russ
2010 XF S/C
FWIW, couldn't figure out how to get a trickle charger to work on my previous '10 XFR with the usual method of plugging into the 12V socket. Not sure if it had something to do with the design of the electrical system. The only method that worked for me was directly clipping the leads onto the battery.
rredfield (02-15-2014)
Jaguar supply a trickle charger but you can obtain exactly the same type for much less elsewhere. The Jaguar one is a rebadged CTEK.
XF Battery Charger - JAF 0046 (10) 1E.pdf
Regardless of which charger you get, the Jaguar accessory leaflet shows the recommended way of hooking it up.
Received 2,266 Likes
FS[MidWest]: 2010 XKR convertible
JaguarJoseph
09-16-2015 11:19 AM
