Trickle charger settings - need help
The battery on my 2010 XF Premium is dead and I'd prefer not to replace it, if possible.
What settings (volts, amps, etc) do I need to set the mobile charger on to try and juice the battery up to fully charged (if possible)?
Apologies in advance for my ignorance.
I am trying to sell this car after having twins and needing to hedge some funds.
Anyone want a deal?!
Not if you are of the mindset to sell a car with a dead battery that you are trying to hide!
Assuming you are ignorant as you say, and not crooked, then I will point out that when a battery is dead rather than just discharged, charging it does not fix it.
What you should do and I won't give any high and mighty lip service either...
But take the battery out or have someone, a friend or neighbor help you if you are unable. Take it to AutoZone or about any auto supply store and they can determine if it is dead or just needing a good charge. Either way you'll know for sure...so you can reveal the issues with the battery to the new buyer or negotiate the price around it..just saying.
And to answer your original question..A battery charger should be set for 12 Volts..it takes care of how many amps and all that...Or use a set of properly installed jumper cables from another running car, will charge the battery too, enough to start the car after a half hour or so if the battery is just drained and not dead..
Good luck
Good luck
Received 2,263 Likes
I believe you are correct, that's what I think too...But I also can see the guy is trying to cut any additional expenses before he sells the car and is hoping all it needs is a charge...I wish he would have said if it has run recently or had been sitting around for a couple of weeks or more...That would make the prognosis more conclusive.
Thanks for your usual constructive and helpful advice.
