Trunk cargo net for the XF?
Folks,
Going by the accessory list for the XF, it appears that cargo organization options for the trunk are pretty limited. Has anyone used or adapted anything from the other Jags to the XF (e.g. trunk floor net, trunk hammock net, etc.)? The collapsible cargo carrier does not have many favorable reviews.
Cheers!
Cheers!
You should be able to use one from a 7-series BMW, which should stretch far and wide enough for an XF trunk.
Check out the link below.
http://accessories.bmwusa.com/ItemVi...&productId=301
I've seen pictures of the collapsible cargo carrier, but what are the dimensions? Also, how does it stay in one place in the trunk? Any special assembly required?
Thanks!
No assembly required. Unfortunately, it relies on a rubber base gripping the trunk carpet by friction alone. As th rubber gets dusty the thing slides around. More weight helps keep it in place. Lengthwise, It is approximately 90% of the width of the trunk floor at the narrow point. It is about 16 inches wide.
It folds flat and stays flat with integral clips. It has two adjustable dividers secured by Velcro. It has two lift handles, one at each end. It really needs a strap at eac end to clip it to the load rings.
mtravis (01-15-2012)
al_roethlisberger
09-09-2015 09:14 PM
FS[Western US]: Jaguar xk accessories for sale
jfitzoz
09-07-2015 04:28 AM
