Trunk mount umbrella holder
Hey fellas,
Does anybody have an umbrealla holder mounted in their trunk? I have been wanting to add one.
What are your thoughts on this? T-2 umbrella holder for JAGUAR XF XJ XJ-6 XJ-8 XJS XJR XK XK8 XKR X-Type S-Type | eBay
https://www.jaguarforums.com/forum/x...-holder-65474/ ?
But that one from eBay looks pretty good too.
Hey fellas,
Will these wear or create a problem in the weatherstripping? I think I would opt for the trunk lid mounted version.
Thanks for all of the responses guys.
Jaguny, having the holders under the weatherstripping was a concern of mine as well. I will have to look and see if they can be mounted elsewhere.
If not, i will just go with the ones the guys posted above. Didn't actually know those were available for the XF.
I think the part number is in the picture Graham posted. Starting with a C......
https://www.jaguarparts.com/catalog/...oducts_id=1353
Warning Triangle Part number etc.
Warning Triangle Part Number is C2C14862
The one shown is a different model that needs sand to be put in the base to weigh it down and is stored loose not in a clip.
The triangle , complete with holder ( made by Hella so a good brand) you want is JC2C 33010 according to my invoice.
According to the instruction C2S 35863
I have just bought one, cost £23.33 and fitted it.
I do not think the fitting instructions have been updated for years so it is listed as fitting S Type X Type & XJ according to my instructions.
Just two screws to fix it. There is a foam buffer behind the clip at the top.
