Trunk not opening
Trunk not opening
I had our 2012 XF at the dealer about a month back with the trunk not opening electrically, only by the use of the physical key hidden in the FOB. They replaced a switch which appeared to temporary fix the issue. Today, my wife once again could not open the trunk electrically or with the key. I've read here that someone had a similar problem that took a long time to fix.
Wondering what problem was found?
Albert
Albert
axr6 (09-16-2013)
