Trunk won’t open and can’t lock car
Old 07-05-2018, 06:43 PM
Quedog26's Avatar
Default Trunk won’t open and can’t lock car
I can’t open trunk and can’t lock car.
_________________
2009 Jaguar XF (added by GGG)
Last edited by GGG; 07-06-2018 at 02:13 AM. Reason: Add vehicle details and move thread
Old 07-06-2018, 02:16 AM
GGG is offline
Received 16,862 Likes on 12,186 Posts
Welcome to the forum Quedog26,
I've moved you post from X260 (XF 2007 - 2015) forum to X250 (XF 2015 onwards) forum. This is the place to post questions about your model.
Old 07-06-2018, 03:08 PM
lotusespritse's Avatar
_________________
I love these types of posts. I wish I could do that. Just spit out a statement with no details and click submit. And then watch, a bunch of people will come on here and try speculating and answering the cause of the problem without having a clue, and then arguing with themselves, and all the while the original poster never comes back. It's hilarious! I love humans.
Old 07-06-2018, 09:00 PM
EXEF's Avatar
Well put!
I think you've covered that situation rather well.
Old 07-07-2018, 06:14 PM
Bigg Will's Avatar
Well if you have the factory keyfob the manual trunk key is what holds the fob on your key ring. Press in the button on the keyfob to release your blade style key, use this to open the trunk manually at the license plate light fixture. Look for the black plug with a key embossed in it. We were ALL once new here so have a look around, with your XF being a 2009 I'm sure well be seeing you again so welcome.
Old 07-08-2018, 09:48 PM
Yep, the Dog hasn't been back online since he posted that message. Let's see how many more take the bait
Old 07-09-2018, 09:50 AM
pdupler's Avatar
Received 1,111 Likes on 699 Posts
Well, we'll give him the benefit of the doubt just this once. He couldn't put his laptop computer in the trunk because it wouldn't open so he left in the back seat instead. But some thief saw it through the window and because he couldn't lock the doors, stole it. Now the OP has no way to get back online.
Old 07-09-2018, 09:06 PM
I am sure your right. We should definitely keep posting solutions to what we think is the problem. And if we have any spare time, we can help out the kid that's going to do the Hellcat swap into his dad's XFR. He hasn't been back lately, but I am sure he will come back, and then he'll be able to read our posts and complete the swap himself without any issues.
Old 07-10-2018, 03:41 AM
christ's Avatar
Maybe he is stuck in the trunk?
Old 07-10-2018, 04:22 AM
EXEF's Avatar
Maybe there were two identical cars in the car park and he walked up to the wrong one?
Old 09-24-2020, 04:05 PM
GonzalesJ's Avatar
Exclamation 2009 jaguar xf supercharged
My jaguar has the same problem with the trunk. Pretty sure its the boot but the trunk it sealed and seats are locked . Master key doesn't work and neither does the emergency key thing . Car has about 117K miles . Currently in Washington.
Trunk has opened randomly but hasn't happened for about 6 months now. I'm aware of removing the rear seat but would like to pointed in the write direction for a DYI
Old 09-24-2020, 05:30 PM
davetibbs's Avatar
Can you be more specific about why "the emergency key thing" doesn't work?
Using the key blade in the trunk is a manual process so if there are wiring issues etc preventing the trunk opening it shouldn't make any difference. Can you turn the key blade in the lock?
Old 09-25-2020, 11:54 AM
GonzalesJ's Avatar
Default 09 Jaguar xf sc
Yes it turns in the trunk but I dint hear anything mechanical moving for the lock.
Old 09-25-2020, 01:07 PM
clubairth1's Avatar
Received 2,416 Likes on 1,901 Posts
I would push on the trunk lid while I worked the key back and forth.
Old 09-25-2020, 01:53 PM
davetibbs's Avatar
Seconded.
Old 09-25-2020, 02:33 PM
GonzalesJ's Avatar
I've tried wiggling the trunk so many ways while trying to unlock manually
Old 09-25-2020, 04:57 PM
davetibbs's Avatar
You may be at the point of removing the rear seat then, at which point you should be able to pull the emergency release cord from the inside
Old 10-24-2020, 11:23 PM
denpin's Avatar
Default Manual key does not open trunk
Hi,
I, too, am locked out of my 2010 XF trunk. The battery had run down, and I used the metal manual key to open the trunk. I connected jump starter and tried to start the car, but with no luck. I then shut the trunk while I went to get another jump starter from the neighbour. When I tried to open the trunk using the key again, it did not open. The key turns, but there is no clicking sound at all. I then removed the rear seat base, but there appears to be no emergency release cord
Any help would be greatly appreciated.
Old 10-25-2020, 11:08 AM
clubairth1's Avatar
No Dave is talking about the glow in the dark plastic handle that is inside the trunk.
I have an XJ so not sure but is there a jumper connection under the hood on the XF's?
Old 10-26-2020, 06:24 PM
BritCars's Avatar
Just open the bonnet/hood and connect a 12v power source. Then use the button on dash to open the boot/trunk
You may need a strong power source or give it some time first as the battery will draw heavily on it as it tries to charge
Quick Reply: Trunk won’t open and can’t lock car
