Trying to Confirm 255-35-20 Winter Tires For XFR
I've been told by Tire Rack that I can put 255-35-20 winter tires on all four wheels of my 2012 XFR. Typically, this size is just for the front tires, since the (summer) rears are normally 285-30-20s.
The dealer is pushing to go to much more expensive winter tires with the same exact specs as the summer ones (285s in the rear). Tire Rack says that the 255-35-20s are fine for both the 8.5" width front wheels and 9.5" width rears.
Can anyone confirm this? I'd rather go with the 255s, since the narrower tire is better for winter traction (less chance of "skiing" on top of the snow...).
I'm thinking a tire that's the same size on two rims of different widths could provide some very funky handling characteristics. Would be a waste of cash to even attempt it to me. I can't even imagine how a 35 series tire could make up an inch of width on the rear rim...just seems wrong...
Contact patch size will be identical. Just the shape changes. You will be better off in winter with the same sized tire front and rear. Staggered wheel sizing is largely a styling thing with very little effect on handling. Wider tires develop the same grip as narrower tires on the same car. The wider rear tire develops more grip at the same slip angle as the narrower tire but only up to the limit of the contact patch. The wider tire breaks away at the same speed as the narrower tire and more abruptly which is bad in winter On dry pavement this charcteristic can sharpen up the handling under high acceleration forces. In winter the road won't give you enough grip for this to occur anyway.
Wow, my XF SC is the WORST RWD car I have ever owned. I got stuck in my driveway...literally, in my driveway in about 3" of snow. Just attempting to switch bays in my garage. Winter mode is a joke too, the car won't move. I had to turn off DSC and Winter Mode to get it moving. Luckily I have a SUV for winter because that thing is useless, I can't imagine a set of winter tires make that much of a difference.
Haha, I recall not being able to move in less than an inch of snow with a Mustang GT...you need tires with at lease a sipe in them before you can say its the worst car ever...there's a few here who'll argue with you.
Would it be fair to say 285's are the widest tires you've ever had on the rear of a car?
I have my 255/35 blizzaks on now all around, and can confirm they fit. Even last night driving in the cold rain, I had better traction than I've had on colder days in the past month. The rubber compound on a winter tire is totally different, and you can tell the difference on days colder than 45deg.
summer tires will do absolutely NOTHING for you in snow and cold temps.
the best thing you can do is get a set of winter tires....and yes winter tires WILL make that much of a difference. I have a G37 coupe with summer tires...switched over to winter tires and its night and day
I started this thread and then conducted more research. I found that 255-35-20s all around on the 2012 XFR will indeed work. I went ahead and had Blizzaks in that size installed yesterday, right before it started snowing in Philly. I drove from Philly to Bethesda, MD through light snow and freezing rain with no issues. There's no snow accumulation down here, but I will post an update on the performance of the tires in deeper snow conditions as soon as I experience them.
jaguny (11-08-2012)
Trying to get information on tires, wheels, TPMS seems to be a challenge with Jags as many suppliers, dealers don't have a lot of experience with the car. What source(s) ultimately did you find that you gave you confidence in the right answer? My salesman has typically provided the most useful information, as he is familar with the car, even moreso than service or parts, when it comes to other than strict OEM setups.
Use only OEM equivalent sensors, Jaguar doesn't make these so they are available aftermarket. Have your tire guy write down the codes on the sensors and list them by wheel, my guy simply crayoned 1,2,3,4 on the inner sidewall of each mounted tire and wrote own the code for that tire next to the number.
Then follow the TPMS instructions in the Owners Hanbook on page 217 for 2009 model, may be a different page for later cars. Should be no problem. Jaguar uses a self learning TPMS and with the codes you can ask a dealer to reprogram the module if you happen to get the fault display.
Mine just worked, four totally new sensors installed and no fault codes. Interestingly, to of each new sensor had the same code. I think the system is set up to accept any new code if the sensor is active ( not hibernating) and close enough to the receiver/transmitter in the wheel well for at least 15 minutes stationary.
285 is def widest tire I have ever driven on...my mustang cobra was 255 I believe. I have an SUV so I won't be throwing winter tires on...but as I said, i was moving from one garage bay to another and got stuck...those YouTube videos of Winter Mode must have some fantastic winter tires for sure.
Ick Snow coming all ready.
When I purchased my 2011 XF SC in December 2011, they offered 0% and a set of winter tire with 2 seasons of changes or 4 changes free and they store the tires at the dealer. I traded in my 2010 Black Prem/Lux and ended up with about the same payment. I had the winter tires installed with in a week and ran them until I left for Florida in March. I do drive my SUV in winter, (why have a big 4X4 and not plow through some deep gulf or Canadian snow?). As the temps in Wisconsin have dipped into the low 30's F, I have noticed a harsh if not bumpy ride as the tires are obviously hard. I am going to schedule trip to my dealer next week to change over to winter tires and report what sizes and manufacturer that were provided by Jaguar.
Regarding driving car with wide tires in an inch of snow, I recall waking up to a freak snow fall in northern Wisconsin in 1985 and attempting to drive my 85' Corvette. At that time this was the first car to be factory equipped with 50 series tires on 16" wheels which I thought were huge. It was an added experience when the posi-traction or limited slip rear axle engaged and the car plowed straight ahead no matter which way the wheels were turned.My next purchase was a 82' Plymouth Reliant for my "winter driver." No tickets or looks with that car. lol I traded a Infiniti G35 Xs for my 2010 XF which was all wheel drive and in winter you could not tell, because it was poor in snow and additionally I could not break the 18 MPG barrier. I would say that certain tires and cars do not perform well in snow.
