Tune2AIR Bluetooth works Amazing... But!!!!
Just got it. Opened it up and is working like a champ in under 1 min! VERY IMPRESSED.
One little issue I'm having is with my 2011 xf prem..
I have an iPhone 5s, paired with the unit and I literally am unable to press pause on the music. It will only pause for a second then starts playing again
it will only stop stop and keep stopped if I either switch off of the portable radio/ iPod option to either aux or radio or cd or sat radio etc... or I turn off stereo completely. Then it stops the music playing on my iPhone. This seems to be the case with iPhone music, pandora, and any other app I use to stream. Just can't keep
It paused or stopped. Any ideas? Or
Is
This what others running same tune2air Bluetooth are having??
Thanks!
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Is
Thanks!
I have the Tune2Air in my 2010 XF Portfolio. I just tested it and found that the pause/play work as expected when using the XF screen. When using the screen on the iPhone 5s itself, mine does the same as yours. I can't explain why but it may be related to the behavior when using the cable connection. As I remember, that used to display a message that the iPhone was being externally controlled and the phone controls were disabled. With the Tune2Air you see the "Now playing" screen instead. This is not an issue for me because I leave the phone in my pocket when I'm in my car.
philwarner
09-05-2015 10:05 AM
