Turn signals on the 2012 XF
If this is at the front it may be connected to the DRL function. US cars do not have DRL active on delivery as far as I know but Europe and Canada do. Some research suggests that DRL should switch off when turn indicators are active.
Does this happen only on the side the turn indicator is active?
During the daytime, the bright LED DRL turns off on the side that the turn signal is flashing for a turn. At night, both LED DRL's operate in a dimmed mode and do not turn off when a turn is signaled. The amber turn signals originate from multi-LED lights that replace the inner high-beam headlamps of the previous model years. The driving high and the low beams now originate only from the two outer headlamps.
OK, I get it. But a buddy has an S5 that had the same issue and a software tweak was done to stop the "winking". He tells me that there is a company (Ross Tech, I think) that sells the software and an ODB II connector that is run through a laptop that can change certain settings in the car.
Otherwise, no turn signals for me!!!
Signal lights are for other drivers to know when you are going to make a turn. They are not for the person inside the car. So many accidents have occurred because of people not using their signal lights. I have a family member who is an EMT and he talks about how many people get t-boned because a car was sitting at an intersection thinking that a car was going straight by, but the car ends up making a left turn (while not using their signal) and the car that was waiting for the person to drive straight by ends up running right into the left turning (non-signal using ) car. So Chairman are saying that you are NOT going to use a signal light, simply because you don't like how it looks OUTSIDE of your car, while you're on the INSIDE? I may be misunderstanding you.
Ross tech is Audi specific. VAG Com software is basically the VW group's factory diagnostic software licensed for public use. You need to buy the "dongle" from Ross Tech and the software is then free. Useless without the dongle but free.
This is not available for any other brand.
For a fee you can get professional mechanic's access to manufacturers software. Jaguar will sell this to professionals.
Richard_gib
09-12-2015 07:08 PM
