Turning the left signal is turning my left headlights off
Hello, i have this problem with my xf 250 that when i turned the left signal, the left low beam turned off. It's not happening when i turned the right signal!
It can be a bulb problem or a bad wire/connector between the flasher unit and the turn signal switch?
Thnak you!
Thnak you!
Bogdan5788 (11-16-2021)
I had the same problem and elected to change the light stalk. After the stalk change the lights worked perfectly.
Link to light stalk change JagRepair.com - Jaguar Repair Information Resource
Gus
Gus
Gus
Gus
apost8n8
03-25-2024 07:28 PM
55chevy
12-03-2013 02:08 PM
