Tutorial or Video for pulley swap?
I've heard the easiest way is to cut the old pulley off and get the centre of the new pulley red hot and push on. The new pulley is S/S
Contact Viezu - Car Tuning, Performance Engine Tuning, ECU Remapping / ECU Remaps is in England with dist. all over the world. I'm using them because they are local here in NZ. I think Viezu write many programs for different cars and then tuning shops put there name on the tune. May be wrong but I think the Paramount Performance tune was written by Viezu.
One of the Exec's at Viezu has an XFR with Tune and Pulley and is very happy with the result, which was another selling point for me.
Received 6,323 Likes
BigCat09 (04-17-2012)
Thanks, that makes sense. I will wait until I get proper intruction from Viezu or someone from here as some pulleys are alloy, some steel and some S/S.
You can use a puller to get it off but it needs to be a high quality puller. It sounds like it's on there pretty good.
You can look over this tutorial. The puller/install tool should work for the Jag. I know it's for a Cobra but the pulling and installing part should be relatively the same. The billet flow pulley setup would be ideal if they made something like that for the Jag. You could swap pulleys easier after you installed their adapter and had a few of their pulleys to try out.
http://www.mustangevolution.com/must...cobra-mustang/
I had my budy look at it cause he has a GT500 and a 04 cobra. He has 2 pulley tools and he checked to see if they fit and they fit perfect. The old one should come off with ease long as the shaft is cold.
To put the new on on he lets the car sit over night and then puts the new pulley in a small toaster oven and then press it on with gloves. Nice and simple like the OP said above.
Jaguar Forums Editor
Jaguar Press release
09-30-2020 06:53 AM
