unleash the beast - these cats can roar!! (open exhaust XF supercharged)
check out the sound and fury of the supercharged 5.0 AJ V8 with backboxes removed.
Liked it so much, i installed electric cutouts so i could have the quiet factory sound and this roar too - all with the push of a button
cyndav6875 (04-10-2017)
direct connect to battery in trunk with 2 amp fuse. i start with a higher amp fuse and reduced it down to 2amp - was still plenty to run both controllers that are twinned together.
no noticeable battery drain issue - i sometimes let the car sit for several days and it starts right up
