USB / mp3 files
USB / mp3 files
Evening
I have converted some audio from U Tube Video's to MP3 format and saved onto a USB memory stick.
When I plug the stick into the USB port in my 2013 XF S I can see the files on the screen all correctly titled.
However, when I select the individual files on the touch screen top play nothing happens.
I'd welcome any advice please?
Ferg
Ferg
Is the memory stick formatted correctly? I think I remember someone saying it has to be in FAT32 format. If it's not, there are free programs that will format it into FAT32. Keep in mind that I'm not all that knowledgeable about that stuff, just "reposting" what I thought I remembered. It's easy to do a search on this forum or Google, though. Good luck.
so far I found out the MP3 work well in the format:
MP3 44100Hz stereo 16Bit 128Kbps
And I use the AVS Audio Converter!
Hope this info is helpful !
regards, dentrix from Austria
Evening
Ferg
Ferg
I gave the same issue did you know how to make it work????
You rencode them to what exactly
Jaguar Forums Editor
Jaguar Press release
09-30-2015 03:08 PM
09-28-2015 05:18 PM
09-25-2015 11:58 AM
