Warning Lights
Received 3,274 Likes
It's a TPMS (Tyre Pressure Management System) message.
I'm guessing you didn't get the TPMS valves/senders swapped over to the new rims, and the system is throwing a hissy fit coz it can't see the senders any more.
Three solutions - get the valves swapped over, get a new set of valves and have them put on (they have to be OEM valves of the correct frequency, two different frequencies, not sure which yours is, they are quite expensive, you can get after-market ones much cheaper but most find them very problematic), or get the system disabled entirely which requires a knowledgeable operator with all the correct SDD gear and no dealer will do it.
BW_Hunter
07-29-2017 07:16 PM
Navionsam
05-21-2012 04:37 PM
charger12
04-04-2012 04:23 PM
