Water pump+Hoses+Alternator+Rear coolant crossover
Thanking you for this post as I have been struggling with this pump from everything including ordering wrong pump to installing it improperly at least 3 times. now have new O rings and going to line it up once more. I am acquiring this vehicle from my daughter and enjoy the car but the information on fixing things that go wrong is scarce.
https://www.jaguarforums.com/forum/x...9/#post1758337
Yes. But if you've never removed the supercharger before, the interference fit pegs underneath it can make it tight. I had to use considerable force (bolting two straight metal bars to the whole supercharger/inlet manifold assembly and rocking it with a gym buddy) to get it off.
maximus150 (01-18-2019)
Thank you for the amazing post @Bigg Will , I'm going to be tackling this on my mom's Jag once I source all the needed parts. She has a coolant leak from a hose between the supercharger and firewall.
What oil did you use for the supercharger service? and what is the recommended/required quantity?
Thanks!
Thanks!
#30
Thanks!
Thanks!
SC supplies=
SuperchargersOnline, Worlds largest Supercharger Resource. Get Serious About Power
jaytee (10-02-2019)
#31
#32
