Water pump installed incorrectly?? Please help
Replacing water pump and new pipe and o rings on my 2010 XF. I installed the pipe first and then slid the water pump on and torqued the x4 bolts to spec and noticed this gap. I have had trouble before trying to get it to sit properly without leaking. I did set the pipe to the correct orientation but just wanted to see if any of you guys who have replaced multiple ones if this looks right. Have the supercharger off now and thought I might as well try to get it to sit right before putting it back on. Thanks!
2010XFPushBrakeHarderToStart (05-07-2024)
gretle_2.0
02-19-2022 05:09 PM
