Water Pump nipple lock
Ugh. I wish I had seen this before ordering a new water pump just for that stupid ******* plastic lock.
The o-ring is installed inside the water pump. Use a small pick to remove the old one from the water pump. The o-ring sits in a groove inside the water pump. The (grey) locking fitting should be inserted into the water pump next. Finally, insert the elbow fitting.
