Water pumps and crossover failures on the 5.0 engines
Just did this repair over the weekend. 2012 XF portfolio 2 months outside of the factory warranty. Of course the CPO warranty does not cover the crossover pipe because it's made of plastic or so I'm told by the service department. Terrible place to use seam welded two piece plastic. In the cooling system no less, WTF, and it's known to fail just outside of the factory warranty period. This is no doubt by design but everyone knows manufactures make their money in parts and service not selling the cars themselves.
My CPO warranty just covered my crossover pipe. Rusnak in Pasadena did the work. FYI
I had the water pump replaced 6 months ago and I ask them to do the crossover and I would pay for the part. They said I would have to pay for the labor because the manifold would have to be removed. They suggested not to worry about it because it looked good and would be covered under warranty if it failed. They were right. They said rubber hoses were not covered, but the hard plastic pipes were.
FYI, I just did this job this week (over 4 evenings) and here's my DIY on replacing all of the plastic parts, even the ones that haven't failed commonly yet, but they are all suspect, so I changed them.
https://www.jaguarforums.com/forum/x...cement-165783/
Adam J (10-11-2017)
#28
I think I posted the part number in my DIY thread. That part basically doesn't exist anymore. It's two separate part numbers now for 2 different pieces.
THanks.
#30
Received 3,226 Likes
I've done some Goggling using the number on the hose underneath (8W93-9F814-AD) and that hose appears to be called the "throttle body coolant return hose".
Although I didn't get an exact hit on that number, this page shows a part with *almost* the same number: Jaguar HOSE COOLANT RETURN FOR THROTTLE BODY - AJ89554
Hope this helps!
Hope this helps!
#31
"I´v gone through every part you list but could not find. Help a brother out I´m loosing my mind searching the web."
Dude, the part numbers were in my DIY list. Let me do the searching for you:
Tube: Terrys Jaguar Parts
HOSE: Terrys Jaguar Parts
Trust me on this one: In the not so distant future, the interview for most white collar jobs will primarily be a test of the candidate's ability to search. I'm sorry, but you would not get the job.
#32
#33
FYI the supercharged crossover pipe is a different part and isn't a 2 piece welded plastic part. Don't know if it will fit the N/A 5.0 engine. It is a sectioned part with hose clamps. Possible to rotate the sections to fit the 5.0 N/A engine? Any jag techs out there to confirm yes or no?
There is a picture of the two different crossover pipes on the second page of this thread.
https://www.jaguarforums.com/forum/x...-151358/page2/
#34
Considering that the plastic crossover pipe in the 5.0 non supercharged engine has had so many issues, does anyone know if this part has ever been updated? I have a 2010 XK 5.0 (non supercharged) and I have been smelling coolant and losing some as well. I have an extended warranty and will be bringing my car to dealership soon.
#35
#36
I replace *all* of the plastic recently, and there's only 2 part number that have changed, and they didn't change significantly. The problem areas are still the same. It's not cheap in parts to do it all, and it's a lot of work, but I don't want to be stranded by the side of the road or blow an engine by waiting for them to break.
bocatrip (01-03-2017)
#37
Better chance your water pump is leaking under those circumstances. The plastic pipes tend to burst at the seams where they are fused together, so you don't get a slow leak.
#39
#40
Bumping this up with a question. I have a 2010 XF 5.0 and I need to change out the water pump. Trying to do it myself. Can this be done easily without a lift? Also what side of the engine is it on? The reservoir is on the right side of the engine bay as I look at it, but it seems my coolant leak is from the left as I look at the car. Any thoughts, pictures, or video tutorials for this would be greatly appreciated. Thanks!!
