Weak Headlghts
I believe I saw one last time I was under the hood. You can also adjust if you have access to diagnostic tools. First thing I would do though is to check that the mounting tabs are intact. When I had a problem with my lights, broken tabs ultimately proved to be the cause.
jagular (09-16-2013)
Unfortunately, the low beams and high beams are not individually adjustable on the 2012 and 2013 models. My low beams are just barely acceptable but the high beams seem to be too high. Although they illuminate the road ok, the brightest portion of the high beams is way up in the trees a quarter mile down the road. In fact, it is rare that an oncoming vehicle will object to my high beams when approaching me on a two-lane road. I asked the dealer to lower the high beams and their tech told me that if he did the low beams would be down in the dirt.
I can confirm the headlights are up/down and left/right adjustable. If you do adjust, do not just angle them up and blind oncoming drivers.
A simple how to:
How To: Aiming Xenon Lights - BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
I still can't get over how sharp the cutoff is on the S2000 projectors.
A simple how to:
It's a common issue I believe with the Xenon equipped XFs. They tend to be aimed down in front of the car and not out enough.
The good news is they can be adjusted.
My 12 has intelligent xenon lights and they are constantly adjusting the light output as I find that annoying at times because the output is quite poor sometimes.
Mine was delivered new with the headlights pointing downwards, terrible. I just adjusted them up by eye using a 6 mm allen key in the adjusters. I aimed them at the same height as my slightly lower Subaru BRZ which also has Xenons. Nobody has flashed me yet.
I suspect these cars are shipped with the headlights aimed down to reduce discomfort for shipping staff who must watch these cars being driven into containers or onto transporters or into ships. These Xenons can be actually blinding under some circumstances.
This adjustment ought to be part of every PDI but, sadly, doesn't seem to be.
I now know these are not self levelling, which I thought was legally required in Europe.
Regarding self leveling, I thought that it was a DOT requirement in the US that all bi-xenon HIDs to have self leveling, which is not to say that DOT requires all xenon HIDs to have self leveling.
OkieTim
09-08-2015 04:48 PM
