weeping air bleeder?
Dear Listers,
Can anyone tell me what this is? I believe it is the "air bleed" location for the coolant system. It is "weeping" coolant. Now it hasn't lowered the level of coolant in the reservoir but I know its not supposed to weep. Any thoughts on how to get it to stop? It the round thing with the cross on it (But I'm guessing you all already figured it out.) This is the wife's daily driver and I really don't want it to let go on her.
Thanks,
Brian Smith
2013 XF supercharged 3.0L
Shreveport, LA
Thing in question
Thanks,
Brian Smith
Shreveport, LA
Thing in question
Hi Brian
Yes, this is the air bleed location for the heater coolant pipes. These screws are prone to leaking, unfortunately Jag only sells the complete tube as far as I know. I'd guess that this https://rimmerbros.com/Item--i-LR055...BoCxU4QAvD_BwE would fit, but I never tried.
When I did the coolant pipes job I found mine un-cracked and simply exchanged the o-ring on it.
Chris
Chris
Yeah, could be something as simple as a new o-ring needed.
However, since these bleed screws are the same size/design as on BMWs, I highly recommend replacing it with this anodized one, as the plastic will eventually snap anyway. I have it and it's great.
Hi Brian
Chris
Chris
washuk
04-30-2010 11:46 AM
