What fuel to use?
Old 11-01-2015, 01:13 AM
fre2bpowerless's Avatar
Default What fuel to use?
The car in question is my 'new to me' XF-R, a '13 MY facelift. The first owner was filling up with regular petrol which is 91Oct+E10 here, I've driven the last 2000 miles filling with 97 octane and its caused my gas consumption to increase, I'm not sure if the performance has improved or degraded with the change of fuel though.
Could the mileage drop be related to the fuel used?
Could I use both 97 and 91+E10 safely without causing harm to the engine? 97 isn't widely available here.
Old 11-01-2015, 09:16 AM
Received 2,263 Likes on 1,845 Posts
Where is 'here'? It's nice to know what part of the planet you're on, as fuel rating systems and engine calibration varies from one market to another.
As you used the word 'petrol' instead of 'gas' I'll guess that you're not in North America. If so, your fuel is probably rated using the RON system. Your owners manual will state the minimum recommended octane level, probably 91 AKI/95 RON.
Old 11-01-2015, 10:37 AM
JagV8's Avatar
Received 4,528 Likes on 3,938 Posts
Odd... I don't think we have 91RON at all - so not sure where the OP is!
Car makers tweak the software (calibrations) per market / region so read the handbook and use what it says. My Jag actually has an OE sticker by the fuel filler saying the minimum (95RON) to use.
Old 11-01-2015, 10:50 AM
DPK's Avatar
DPK
DPK is offline
I don't know about the anemic 3.0's and 2.0's, But the V8 requires the highest top tier gasoline you can find..A fuel blended with 10% Ethanoil will decrease mileage as it has a lower BTU content, so therefore the engine uses more to get the same bang for the buck as 100% fuel
I use only Shell Premium at the octane rating of 91..which pisses me off, because that is the highest I can find in my area...I want 93 octane at least, for optimum engine performance.
Old 11-01-2015, 11:52 AM
XJL's Avatar
XJL
XJL is offline
Follow what the owners' manual requires!
Old 11-01-2015, 12:14 PM
n8ertot's Avatar
Here's an interesting gif that talks about the inner workings of an engine. The octane section has some really interesting info that is pertinent to this.
EDIT: Apparently you can't upload a gif, so I'll just type out the relevant info.
"Using higher octane fuel in an engine designed for lower octane simply wastes money and can result in less complete combustion, resulting in lower fuel mileage.
Gasoline's octane rating refers to its resistance to autoignition.
Autoignition occurs when the fuel-air mixture is ignited by compression alone, without any spark. This can contribute to engine knock and is generally destructive. High performance engines often have higher compression, which requires higher octane fuel to prevent autoignition. "
In short, if you're using an octane other than what the engine was designed for, you *may* see decreased mileage.
Old 11-01-2015, 12:30 PM
91 octane not RON, European octane. I'm from India. The manual doesn't specify permitted Ethanol content. I think 95RON is what's recommended for the XF-R.
Old 11-01-2015, 02:43 PM
European octane rating is the RON system, which I believe India follows. If so, use fuel that is 95 RON or higher to obtain full potential.
Don't worry about 10% ethanol (E10). All Jags built in the last 20+ years can use it. Loss of power and fuel economy is approximately 3%.
Old 11-01-2015, 03:05 PM
boiler's Avatar
The fuel door sticker on my XFR says 91+.
Where in OKC are you I always put ethanol free 93 in my STi while we lived in Edmond.
RS fuel off the turnpike near May has 93 without Ethanol however it is about $1 more than ethanol free 91.
Old 11-01-2015, 03:14 PM
Has anyone done any testing on the track or dyno with an XF or XFR indicating that 93AKI actually produces more power than 91AKI?
Paying a buck a gallon more for ethanol free in order to gain 3% mileage/power makes little sense.
Old 11-01-2015, 04:00 PM
DPK's Avatar
DPK
DPK is offline
South side...sw119th and May....we use to have a Sinclair at I-44 and sw 134th that sold pure 93 octane..but haven't seen one since..you'd think SHELL would have it at least..91 is at the bare minimum you want to use.
Old 11-01-2015, 04:59 PM
Received 4,454 Likes on 2,426 Posts
If in doubt, check your owners manual....
As for Octane ratings, it's confusing on an international forum, people should really be clear if they are talking about AKI or RON numbers.
In any case an E10 91RON is not what i'd be running in an XFR... the engine management will adapt but it's not exactly a "premium unleaded" which is what these engines demand. Minimum 95RON would be the usual recommendation! (equivalent to 91AKI)
You saw an increased consumption changing from E10 91RON to straight 97RON? That's the opposite of what would be expected...
Unless you've been enjoying an increase in power and using your right foot a bit more...
DPK (11-01-2015)
Old 11-01-2015, 07:32 PM
I did a little digging and confirmed that the octane ratings of petrol/gas in India are expressed in RON. I also found that only two grades are commonly available, the 91 and 97 RON mentioned by the OP, with nothing in between.
These ratings are roughly equivalent to 87 and 92 AKI. The 2013 XF/XFR owners manual, at least for North America states the following:
OCTANE RATING
Premium unleaded gasoline with a Cost of
Living Council (CLC) or Anti Knock Index (AKI)
octane rating of 91 or higher should be used.
Using unleaded fuel with a lower than
recommended octane rating, can cause a
persistent, heavy engine knock (a metallic
rapping noise). If severe, this can lead to
engine damage.
Note: Mid or regular grade gasoline with a CLC
or AKI octane rating of not lower than 87 may
also be used, but performance and fuel
economy will be reduced.
Emphasis is mine.
Old 11-01-2015, 07:38 PM
DPK's Avatar
DPK
DPK is offline
Exactly...I as an experiment ran 10% ethanoil in my lawn mower..I had to fill the tank twice to cut my entire yard...back on 100% pure gasoline, One tank to cut the whole yard and still had some left over in the tank..
3% difference is a very conservative number as far as mileage difference...I think it is more along the lines of 7% to 8% in most cases..So it makes perfect sense to buy and pay per unit a little more of 100% vs E10, as you can go further but fill up less, so the cost is about the same over all and it's better for all of the engine's concerns too..To say the engines can handle Ethanoil is just asking for future trouble throughout the fuel system.
Old 11-01-2015, 07:41 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
\Your lawnmower extrapolates to your XFR! LMFO!
Swimref (11-02-2015)
Old 11-01-2015, 07:45 PM
DPK's Avatar
DPK
DPK is offline
You know the point I was making...
I did run the moonshine in my HUMMER once for a while and it too showed terrible mileage with it.
Go ahead zapper..say something about HUMMERS, as we all know they are gas guzzlers...
Old 11-01-2015, 08:09 PM
boiler's Avatar
Considering the tune on my STi was for 93 it did make sense. Not to mention I noticed a tremendous difference on the butt dyno between fuel with ethanol and non ethanol. Also the car was drove a few times a week meaning I only filled up max a few times a month.
Old 11-01-2015, 08:16 PM
boiler's Avatar
When we lived in Denver the terrible gas damn near killed my mower, once we moved to OKC and I started running ethanol free gas it ran just fine.
DPK (11-02-2015)
Old 11-02-2015, 03:03 AM
I had some experience of running the XJR on various fuels in the UK, Continental Europe and Australia.
97 & 99 RON in the UK
100 RON in Germany & Switzerland
98 RON in Australia
Same car, different fuels, very different highway economy.
I got the best highway economy on the 100 RON, even though it was with higher speeds on the open road.
Old 11-02-2015, 09:50 AM
Ummmm, no.
While some parts of the world only recently started using E10, it's been in common use elsewhere for 30+ years. In many areas, the only thing new are the labels on the pumps advising consumers of the ethanol content. The fuel itself didn't change.
I've been using E10 for over 20 without a single issue. In that time, I've accumulated sufficient data that proves the real-world loss of mileage is ~3% which matches the calculated loss quite accurately.
This is slightly more credible than mowing the lawn once.
Much like the ill informed predictions of doom and gloom when lead was removed from gasoline, I'm sure the E10 myths will still be around 30-40 years from now.
Swimref (11-03-2015)
Quick Reply: What fuel to use?
