What goes when on an XFR
I'm currently looking to get a used XFR, probably a 2010 one with average-ish mileage on the clock. So far I've discovered a few things that tend to go 'prematurely':
Water pump;
Suspension arms (lower only?);
E-diff motor;
Tyre pressure sensors;
Windscreen delamination.
Any feel for when things typically go, if they're going to? Are replacements any more robust? Are there any other common faults/failures to watch out for?
Also, I've historically thought a higher milage newer car would last me longer than an older, lower-milage equivalent for the same cash. Any thoughts on this philosophy would be appreciated!
Water pump;
E-diff motor;
Received 3,209 Likes
Everything else was straight legit repairs. Actual seepage and leaks.
Thank god for an extended warranty!
Owner's predictable response: "Thank god I paid $5000 for an extended warranty!"
Aside from covering expensive repairs...the extended warranty helps sell the car when I move onto the next.
Originally Posted by Kaeghl
I think it is weird that they replace the entire control arms.
I already had a shop here look at mine and they already found new bushings that would fit.
But as you say if you can do the bushings easily and the arms aren't bent or damaged then that's a good approach
What do you think an inspector gets paid per hour? Benefits? A little extra cash on the side wouldn't hurt.
Had the following replaced on my 2012 XFR in the last 12 months. Current mileage 35k
Anyone else had suspension arms replaced around 35k miles and then again at 70k? I'm basically wondering whether finding one that's had suspension arms and water pump done is likely to mean those parts will be good for 100k miles or if I need to consider them as 'consumables' that'll go every 40-50k.
