What is this sensor? XF 4.2 SV8
Looks like there is something else I need to order so I can address it during my leave next month- this sensor at the left-front corner of the engine, middle of the photo, is weeping oil. Can anyone tell me what it is please, even better, how it seals- e.g. o-ring etc?
On the 4.0 liter in my XK8 I did not remove the valve cover, although it is recommended by the service manual. I replaced mine by disconnecting the electric connector on top and sliding the new ring down into place. This after removing the old O-ring and cleaning the area of course. No further leaks for over 8 months.
moose jaw trucker (08-17-2022)
Seal pops out
Hi not sure if this was answered or not, but the seal itself pulls off
I myself am wondering if these are leaking, will it cause a vacuum leak ? I’ve recently just replaced the brake booster seal from the throttle body manifold as had a high leak, but now I’m getting lean codes after a long journey but no cel lights anymore
To fit the new one just slide it over the VVT sensor and push down firmly.
Despite what it says in the workshop manual removing this seal before taking the valve cover off makes removing the valve cover much easier as it gives you more wiggle room to get it clear of the VVT sensor, i.e. you can change the VVT sensor seal without taking the valve cover off. I suspect they say to remove the valve cover to make you change the valve cover gasket and o-rings as they are probably coming to their end of life too.
I replaced a leaking VVT seal on one bank last year, then 6 months later had to replace the valve cover gasket and spark plug o-rings because they started leaking, which meant replacing the VVT seal again. In the last year I've replaced both valve cover seals and the o-rings due to leaks, it was actually relatively straight forward to do.
You might want to check the PCV system is working properly, you might have excessive pressure in the crank case that isn't being relieved properly so its forcing its way out via the VVT sensor seal, if you plug that leak its going to try and find somewhere else to get out. A typical thing on this engine is that the PCV hose back to the throttle body gets brittle over time and creates a vacuum leak, preventing the PCV from operating properly. Run your hand or a cloth along the PCV hose and see if there is any oil on it, if so its probably leaking and needs replacing.
