What size spacers for XFR
Looking to get wheel spacers and from what I’ve gathered 25mm in the rear seems appropriate. For the front am I looking for 15 or 20mm? I’ve looked at a few threads but there were non XFRs. Pictures would be helpful. Thank you.
VicVegas84 (02-09-2024)
lol I bought them and they’ve been sitting around waiting to be installed. Have been too busy at work/life. Ill give it a shot next week. Need to get a grinder to cut the front studs off a little bit for the 15mm spacers.
Received 3,225 Likes
No problems with the stock XFR wheels (such as Nevis) that I am aware of, or do you have non-stock wheels?
For stock F-Type wheels yes all except the Blades need the studs trimmed for 15 mm spacers to fit as the voids in the back of the wheel between the stud holes aren't deep enough for the original studs to clear but I didn't think this was a problem with stock XFR wheels.
Why?
I have stock wheels. there are a couple of videos l watched where 15mm required some of the wheel studs to be cut off. Here’s one:
https://youtu.be/aEIEV8ff8WI
Yes, the wheels in that vid are Nevis and I had the same on my 2010 XFR.
Where I got mixed up is I put spacers on my old XFS (with the stock 18" Venus wheels) but I replaced those wheels with 20" Coventry Whitley wheels in XFR spec sizes (but different offsets), and then I swapped those wheels over to the XFR, so I never did put spacers on the XFR.
So now we know that Nevis are the same as many/most Jag wheels and can't take 15 mm spacers without trimming the lugs.
Are those spacer.Still available? I’ll buy them now please.
