What is a VIM Modulator on XF Supercharged?
Received 3,223 Likes
"General Information - Diagnostic Trouble Code (DTC) Index DTC: Steering Column Lock Module (VIM)
Description and Operation
Steering Column Lock Module (VIM)".
Of course absolutely nowhere does it say what VIM stands for or means!
Here are the two pages from the Workshop Manual:
Edit - I suspect it might mean "Vehicle Immobilizer Module" seeing as it relates to the steering column lock.
info
Good morning! I'm new to the forum! Can I ask you why did you have to replace the VIM? what problems were you having? I also had a problem with an error code on that module ... that is the error B100D-87 and the car did not give authorization to start. I had to disconnect the battery for 10 minutes and then it started! thanks in advance for your help! I would like to know if it is my same problem so I change the module too.
ixj8it
11-07-2012 11:45 PM
