Wheel Spacers Nightmare
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
Hello Friends,
I' hoping someone can assist me with this issue. I have aftermarket wheels on my 2013 Jag XF. Unfortunately the guys who put on the wheels did not consider that at some point I would have to replace my brake pads. Now that I am at that point, there is absolutely NO clearance between the caliper and the rim. So I have tried H&R Adapters- 15MM. They didnt fit due to the wheel not being able to sit flat against the adapter. I am in search of just a 1/4 in spacer, but they are very hard to find. Any suggestions? I dont want to have to go to 20MM spacers as I think that might be too much, however that would fix the issue I have with the wheel sitting flat against the adapter.
HELP!
HELP!
um.. no. something has to be wrong with the reinstall. The thickness of the new pads should not be a factor in hitting the barrel of the wheel. Unless the barrel is really weird.
Reinstall everything, and then cross torque the nuts with the wheel in the air and check for rubbing. If its still in there you can shave the caliper down a bit with a dremel or sander.
I am assuming you are hitting the spokes of the wheel. Move the caliper around a bit. I just cant see if it fit before, that new pads would make the caliper hit.
Received 3,232 Likes
It seems very strange that the wheel won't sit flat against a 15 mm H&R adapter/spacer, the back of the wheel (mating face) must be a weird shape indeed. I really struggle to see how the wheel can sit properly flat against the OEM hub but not fit properly on an H&R spacer.
I have changed pads and/or rotors on the 380 mm front brakes many times, and there is no way you can install the pads or calipers "wrong" without it being immediately obvious that things aren't fitting and looking like they should.
You could maybe try a 5 mm flat (non-hubcentric) spacer, heaps out there on Fleabay for not many $. A 3 mm one would be better but I think they are fairly rare, and with the 5 mm one you should have just enough lug thread still showing to get the lug nuts done up properly.
