Wheels Fitment Question
What width and offset are the Sentas? Is the wheel you mentioned an OEM or aftermarket? I am having a very tough time finding a 19" aftermarket wheel that will fit my 2013 3.0L AWD which has 20x8.5+49 at all four corners and there's no way an aftermarket 18 would fit but maybe an OEM one could be squeezed on. The thinner 8.0+52 wheel with a higher positive offset will move the wheel outer lip 10mm further inward which will probably look weird.
I'm in the same boat as you. I'm looking for 19s with a 245/45 tire so I can get as much sidewall as an 18" wheel.
It depends almost entirely on what front brakes you have on your car.
If you have the 380 mm brakes then no OEM JLR 18" wheel will fit over them and the only 19" JLR OEM wheels which will fit are F-Type wheels.
I know of no after-market 19" wheels which will fit although there may be some, and I doubt if there is a single after-market 18" wheel which will fit, although a custom made one (read very expensive) might just.
If you have the 355 mm front brakes then almost all OEM JLR 18" and 19" wheels (XF and otherwise) will be fine.
How do i know which size brake caliper I have, is it on the caliper somewhere? I will admit the front calipers are huge and was told that it will be tough to get an aftermarket rim to fit.
My 2010 Premium 5.0 V8 had 19" Autura wheels factory. I was able to get a set of 18" wheels from Discount Tire Direct to fit for my snow tire setup.
But there were only a few of the many 18" wheels they offered that fit over the front caliber/rotors.
Discount Tire was successfully able to tell me what wheel would fit and what would not.
jahmezis45 (02-24-2018)
These are what I had on my 2010 5.0 N/A.
https://www.discounttiredirect.com/b...-dr-33/p/13803
You can get them in silver also.
Just whip a front wheel off and have a look, you should see either 380 or 355 "written" on the bracket.
FastKat
11-01-2020 09:18 AM
FS[Western US]: fs: staggered Black 20" Rohana wheels, Jaguar fitment
polarisnavyxj
06-10-2016 09:34 AM
FastKat
09-23-2012 10:01 PM
DocinMD
11-03-2011 02:37 AM
