White smoke after installing K&N filters-2010 XFR
About 2 days after installing the new filters, I began to see a lot of smoke. The check engine light came on and felt like I lost all torque. I took it to the dealer and now they can't find anything wrong with it. They sent the codes off to some engineers on the East Coast, but they don't think they will find anything either. I was reading that I should have soaked them in warm water first to get excess oil off and then let them dry. Anyone ever have this issue?
What I always did with all my K&N filters was, I let them sit out in the sun for 3 days to dry and/or blotted them dry with a towel to remove excess oil from them. Never use compressed air to blow off the excess oil but rather blot them dry with some towel and let air dry in the sun for a day or so before first use and after cleaning.
If any oil gets sucked into the intake path and gets o nthe Mass Air Flow meter element your car will start to have some issues. I forgot which type of MAF is used on our cars so I cant be sure how to tell you how to clean it if you can even do so. Some are hot wire resistor type and others are film type, not sure which is on ours.
Received 2,192 Likes
no but i can tell you that on all dual filtered jags now we use "matched set" air filters that are manufactured on the same day useing the same material. jaguar has found that the slight variances just in material has/does cause airflow imbalances that affects the engine running and AFR's. Kinda why I no longer recomend any air filter unless theyre matched sets regardless of who makes it
plums (10-24-2012)
I have the K&N filters in mine and never had a issue. You just have to make sure you only oil the side that faces the inlet to the airbox after cleaning. I have had them in since 2010 and so far so good. I believe Jag makes their MAF system to sensitive to sudden changes, Dirt and debris are changes that collect over time. IMHO..
FUNNY TOO HOW IT GOES INTO 1 TUBE AFTER EACH FILTER AND MAFS. BUT IT DOES CAUSE ISSUES. DOES IT IN ALL CARS. NOPE. BUT ITS DONE IT OFTEN ENOUGH THAT THEY ISSUED A TECH SERVICE BULLETIN AND NOW SUPPLY DUAL AIR FILTERS IN A MATCHED SET. DONT KILL THE MESSENGER K
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
DONT ASK ME I DONT ENGINEER THE SOFTWARE OR THE CAR. I JUST HAVE TO FIX IT![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
FUNNY TOO HOW IT GOES INTO 1 TUBE AFTER EACH FILTER AND MAFS. BUT IT DOES CAUSE ISSUES. DOES IT IN ALL CARS. NOPE. BUT ITS DONE IT OFTEN ENOUGH THAT THEY ISSUED A TECH SERVICE BULLETIN AND NOW SUPPLY DUAL AIR FILTERS IN A MATCHED SET. DONT KILL THE MESSENGER K![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Maybe I got lucky and K&N issued mine as a match set. I purchased them directly from K&N shortly after they introduced the filters for the XF. A lot of what you said sounds logical. I'm also wondering if it makes a difference between the supercharged engine vs N/A engine.. The supercharged engine sucks more air in even at idle as oppose to the N/A motor.
![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
I do have K&N's in my car as well. Never had an issue. The original poster could pull the MAF's and clean them out with some MAF cleaner (electronics cleaner) if he thinks the K&N oil is the cause. Maybe he knocked something loose or didn't hook something back up when he was installing the filters.
hey brutal..
Maybe i got lucky and k&n issued mine as a match set. I purchased them directly from k&n shortly after they introduced the filters for the xf. A lot of what you said sounds logical. I'm also wondering if it makes a difference between the supercharged engine vs n/a engine.. The supercharged engine sucks more air in even at idle as oppose to the n/a motor.
Okay the bulleting is jtb00161 back in 2009 and sc xf's only r00019-r47153 after that all came from the factory in matched sets. The issue is with imbalances greater than 2.5kg/hr. Between the l/r mafs. If its closer than that your okay![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
greater than it"may" cause rough idle, and misfires on cold starts
Might I add it started smoking after my first run on the dyno (Dyno Dynamics). The first run was 395hp at the wheels and then we stopped to troubleshoot what could be causing the smoke. At this point no check engine light. After about 15 minutes of us talking through everything, we gave it another run and hit 408hp before it just completely took a dump on us and the check engine light came on. The car still ran, but felt like it was all motor and was still smoking (like if you just put on a new exhaust), so I elected to have it towed on a flatbed to the dealership. Glad it happened during the first run because I was in the process of getting a new pulley getting the ECU tuned. I'll probably wait a bit before getting that done just to make sure this doesn't crop back up.
Well, yeah, it shouldn't have a bearing on this situation. Plenty of people put there unmodified vehicles on dynos with no issues. The only thing I could think of is the MAF not liking the new filters. Dyno or not, I wouldn't expect to have this issue, but am going to go back to stock filters to test.
