will a 20/9 rim with a 285/30/20 fit on xfr
Thinking about putting some 20/9 rims in the front and 20/10.5 on my 2010 xfr. Question has anyone put this rim width with 285/30/20 on the front. Rear tires are new so id like to keep them and want the wider rear rim so I can put more tire there. Thanks Gents I appreciate all the wisdom you share
any offset recommendations are also appreciated
also, and for me a larger issue, you are putting a 30 series sidewall on the front and you'll bend the wheel even easier as that a lot of weight to crash into bumps and potholes.
do you need that wide on front? Jag doesn't think so.. on any of their cars. widest they put on front is 265
I would stick with either 255 or 265 width front in a 35 series on a 20" wheel
For rear, a 295/30 if paired with the 255 width front and a 305/30 is paired with a 265 width front
You'll find these tire section width within the allowed / recommended range for those wheels you intend
The main driver for me to match as such would be tire height matchups. The stock xfr setup has a slightly taller front tire than rear with the 255 front and 285 rear
If I had to do the whole thing over again I might go with a 19" setup and a 40 series front / 35 series rear sidewall for reasons of bent wheels due to potholes.
I intentionally skipped addressing your offset woes. See a tire shop and make that their problem. I rolled my rear fenders b/c I had rubbing on launch or big bumps with the wheels I have and 295 width tires
Tijoe
37
07-09-2021 08:02 PM
