Will updated Nav DVD fix this?
I just purchased a 2009 XF Premium Luxury on Friday and so far I absolutely love this car. However, one frustration is with the nav system and the fact that it will not let me input a destination while moving. I understand the safety aspect but it allows me to do everything else plus I could always have a passenger input an address.
I pulled out the DVD this evening and it is the USA & Canada version 2007-2008. I see the 2011-2012 version is available online for $200 but before I buy the newer version, I'm wondering if it includes any updates that will fix this and allow me to input destinations while moving.
Thanks for any help,
Karl
Karl
Karl
Karl
Last edited by Jerry S; 08-06-2012 at 07:47 PM. Reason: Added the word "for" in first sentence
edobernig (08-06-2012)
Not being able to input a destination while in motion is definitely a giant pain. Blame the government, not the carmaker. There are a couple things that can ease the pain somewhat.
1. Every time you stop the buttons go from gray to blue and will accept input, even with the engine running. In stop & go traffic you can usually complete the programming by the second red light.
2. Even while in motion you have 6 different destinations you can select, home and 5 preprogrammed ones. Set it up in advance with your 5 most common destinations, then you can select any of these (or home) even while in motion with one button touch.
Karl-
In answer to your two questions....
1. A more recent disc will not overcome the issue of data entry while in motion.
2. The more recent disc will have more current map data plus any system software updates.
I tend to buy a new one every third year and sell the old one on ebay. You may be able to find a more recent one than you have there. What you can do is to look at the DVD proper and there will be a two letter code as a suffix to the part number, "BH" for instance. If you have a "BH" disc, a later one will be labeled "BI" or "BJ" for example.
We have the destination input available when driving down here in NZ. I think its the same in Europe as well.
I remember when I had a Lexus (has the same files on the DVD) there was instructions on the net to make a hybrid disk which would let you input a destination while driving. Worked great.
I drove a 2009 and 2011 XF and both wouldn't let you poke at the GPS above 5MPH if I remember correctly. The newer GPS system in the 2012 model does not have that restriction. It does pop up with a window warning about making adjustments each time you go to the map after starting your car, however.
trosty
26
12-18-2022 06:40 PM
