Window regulator stalling
The drivers window on my XF is malfunctioning in that when the 'up' button is activated, it will go part-way up then back down, usually closes properly on the third attempt. I assume there is an overload function in the system to prevent me crushing someone's head. Is there a usual cause for this on these vehicles, along with a usual fix? Presumably there is a tight spot either in the window channel or the gear train of the regulator.
removed the door card, works fine, this is a sign your window regulator motor is dying. It goes halfway up then down, if you keep trying at some point it will get hot and do nothing, if you have the window auto up down function active, you can disable it by disconnecting the battery for a minute, it will work again, the cure for this is changing the whole window regulator assembly.
Same issue here,
martek
09-13-2018 06:02 PM
PaulBarrrera
01-14-2015 01:56 PM
