Winter Tires size
Hi
I'm driving 2010 XF Portfolio with 255/35 R20 all season tires. Now I'm looking for winter tires - should I go with the same size or smaller/narrower?
Somebody suggested 19" but I am not sure why and what width should I go for then?
If you are really riding on 225/35 20s, those are much narrower than what would normally be fitted to 20 in wheels on the XF - did you actually mean 255/35? If so, you should just stick with that size. Even is they are staggered with 275 on the back, you could go to the 255/35 on all four...
There are a few brands that carry winter tires in the 255/35R20 size, but you would likely experience somewhat better snow/ice performance with 18 or 19 in wheels and narrower tires. Of course, then you're investing in an additional set of wheels for what will likely not be a monumental leap forward in snow performance...
The investment in a tire and wheel winter set up is probably a break even deal over 4-5 years of ownership. I switch the rubber on my oem 20 inch staggered setup at $160 per change over. That's $320 per year . I have one of the two top rated snow tires, Nokian Hakka R's (spelling abbreviated). Going into my second winter now. I would recommend dropping down a size and getting a dedicated winter wheel/ tire setup. Any advantage gained in driving with a smaller wheel/ tire is warranted. If you only drive in the city then maybe dropping down a size could be reconsidered. I drive on interstate and in changing elevation terrain and would have liked any advantage. My oem wheels have been scuffed from winter driving and the change over cost is steep. I figure you can likely get half of you investment in the winter wheel tire set back if you sell the car. It is costlier up front as you will need a tpsm set also. If you don't have an XFR or SC then smaller wheels are easier to source and cheaper. Just my thoughts.
JaguNy,
You seem to be very familiar with tire/wheel sizing and fitment so please let me know if you can answer the following;
My 2012 XF is running on 18 inch OEM wheels and 245/45/18 tires.
What specs would I need for the wheels and tires if I want to minus one down to a 17 inch winter tire? OEM wheels are 18x8.5 5x108 bolt pattern with an offset of 49mm.
I appreciate any input that you can provide. Thanks.
Ed
Ed
JaguNy,
Ed
Ed
JaguNy,
Ed
Ed
JaguNy,
Ed
Ed
JaguNy,
Ed
Ed
You already have 18inch wheels - and the total size of the wheel + tyre is almost identical. You have 2 inches less in diameter of metal wheel but you have 2 inches more of rubber sidewall (almost one inch all the way around the tyre). See link to a tyre size calculator below - if you put in 255/35/20 (the 20inch setup) and 245/45/18 (your setup) you'll see there is only a 1% difference in total diameter - hence you have a lot more rubber tyre sidewall.
Tire Size Calculator - Compare Tire Sizes
So you already have plenty of sidewall and your wheels would be great for the winter.
As someone above suggested, you could consider putting winter tyres on the 18inch wheels and getting a set of Jag 19inch wheels to put your other tyres on (although you'd need a new set of summer tyres as the current ones wouldn't fit a 19inch wheel).
Hope that helps to explain. If I were you I'd just get a set of 18 inch snow tyres and swap them over - it's the cheapest option - although as Jaguny says if you plan to own for a while then maybe a cheap set of 18 inch wheels for the winter tyres would pay off.
that's what I drive during winter
the haccapelita r very expensive in size 20 but very good tire on snow on ice and you have a good traction too!.
Thanks everyone for your input.
Nate 96,
I see that you are using the Nokian WR2.
From what I have read there is now a Nokian WR3 and while built as a good snow tire, it as being advertised as an all weather tire. Not all season but all weather. Consumer Reports and many other magazines have rated it very good as a snow tire and good as a summer tire.
I spoke with a Nokian dealer here in New Jersey and he can get them in a day or so in my 245/45/18 size. He also raved about them for all types of weather and a set of 4 OTD was under $1,000.
Are you planning to run them all year round? Did you use them this fall and summer and how did they do? I am really interested in this tire. Thanks.
Ed
Nate 96,
Ed
Ed Ogintz,
I have only been running the WRG2 for a couple of weeks. In those weeks I have seen a wide variety of weather. It has been -22F, snowed 2 feet then warmed up to 50F then below freezing. I have ran dedicated winter tires for the last several years. I must say that keeping in mind that WRG2 are considered an all weather tire it does well. Where it lacks is on the ice compared to the winter tires. Not that it is bad, it is actually good just does not compare to the winter tires. On the snow and in the cold the tires are great. I am very happy with the tires. Since it is not normal to be driving on ice it is a reason I choose them. I also have an XFR so that torque doesn't help haha. The reviews I have read are that the WRG3 are better but are not available in the 20's that I needed. I plan on running a dedicated summer tire.
spanky145 (12-20-2013)
Nate 96,
Ed
Nate 96,
Ed
Gerard Radimaker
09-13-2015 10:33 AM
