Wiper Reservoir leaking
My 2012 XF has developed a leak in the reservoir, this occured before the very cold weather set in. I have never had a problem like this with any car, had anyone ever heard of this in these cars?
The car is going to the dealer for that and for them to look at the "power strip" in the console, which used to, but no longer charges my iPhone 5s.
I'll post solutions/fixes when it comes back from the dealer on Tuesday.
I am bringing my car tomorrow morning, I'll let you know what happens (second trip). The last visit was a disaster. They filled the reservoir with a mixture of fluid and water. They tried to give me some BS about different mixtures. I called the service "manager" and told him that I'll spent the $2 for a gallon of solvent good to -20 if they cannot afford it.
The damn "fluid" they put in last week promptly FROZE that night and I could not clean my windshield the next morning. Later in the day it worked fine (the temp rose to about 35 when I left work). Then they had the gall to send a survey, I'll fill out the survey after they fix the car (they need to flush the entire "system" and refill it with the proper fluid).
You have had unseasonably cold weather and your local dealers may not be aware how important it is to use washer fluid with the correct concentration of methanol (the most common washer fluid anti freeze). Failure to use the correct fluid will cost you in frozen and burst components.
Up here the minimum we put in our cars in winter is rated at -35C (about -30 F) and some places need -40C fluid.
"Mixing" fluids with any water is a bad idea. Unless you know for sure what the existing stuff is rated for and exactly how much is still remaining adding any water can dilute the fluid above the freeze point.
CaneCounsel007
11-13-2015 09:05 PM
OkieTim
09-08-2015 04:48 PM
