Wiring diagram needed for 09 XFs/c if possible.
Hey guys. I'm having issues with my Auxiliary Coolant Pump. Like many i've been experiencing the old RP mode linking to the pump in question showing circuit range performance. Installed new pump,bigger and better still had issues P2601circuit range performance. Checked fuse has lower power running to it. Does anyone by chance know which relay controls this pump. I have been told that its shared with the blower motor. Any guidance with this would be appreciated. CHeers
Received 3,231 Likes
You can download a PDF of the 2012 XF wiring diagrams from my Dropbox here: https://www.dropbox.com/s/tacin632na...grams.pdf?dl=0
May not be identical to the 09 XF but most of it should be the same!
guanshee
03-19-2018 11:53 AM
beady
08-27-2015 06:38 PM
