X pipe replacement questions
I have done several modifications to my 2013 5.0SC.
I first removed the whole center section and installed straight pipes from the cats to the mufflers. It sounded great inside the car. Outside it sounds good until I went more than about 50% throttle, then it got a sound like a metallic rattle.
I tried to reduce that metallic rattle by cutting out the muffler valves but it did not help and I actually did not notice much of a tone change with the valves deleted.
The performance fell at off-idle and low throttle. At wide open, I could not tell much difference, but off-idle performance was less.
I recently had an "X" pipe installed in center section (no middle resonators) and my low end power is MUCH better. The sound is very smooth and very European sounding. Used to sound like a Mustang but now sounds like a much higher revving Euro motor.
I love the sound and performance now.
As I understand what and "X" pipe does is it smooths out the "pulses" from each firing and helps scavenge the exhaust gases out of the cylinders and that helps reduce the amount of force it takes to suck the next intake charge into the cylinder. It basically acts like a syphon pulling the exhaust out instead of having to be pushed out by the next incoming intake charge.
I love my new "X" pipe.
I love the sound and performance now. I love my new "X" pipe.
I liked the sound, there was maybe less popping on deceleration but the roar had more rasp in the mid to high range.
I found the main benefit and difference in driveability was a very noticeable increase in pickup during hard acceleration at freeway speeds. It made more of a difference there than i was expecting.
Received 3,209 Likes
I went from dead stock to H-pipe plus after-market straight through mufflers, and it was too droney for me.
I then put the stock rear mufflers back on and kept the H-pipe in place, and that quietened it right down and eliminated the drone completely.
It probably ended up a bit too quiet for some, but it was "just right" for me.
I'm 99% sure that fitting an X (or H) pipe to an existing axle back system will not increase any pre-existing drone, and it's much more likely to smooth the sound out a bit and maybe reduce the drone a little.
