X250 driver window problems - anti-trap kicking in
Hello all
Long time reader, first time poster! I've got a weird issue with my driver side front window in that when I go to close it the anti-trap feature keeps kicking in and lowering it again. After 3 goes I can then send it all the way up but have to reset the one-shot calibration.
If I inch it up without using the 1 touch it will sometimes go without interruption, and sometimes will go up fine on the 1 touch!
Could it be the door control unit, regulator or wires most likely at fault? Hoping to get the door panel off soon but not sure what I'm looking for. Should I pop some silicone grease on the cables to be on the safe side? Going to sort out a door rattle from the window wires while I'm in there too!
Cheers!
Cheers!
EscapedApe
03-19-2016 01:28 PM
