XF 2WD Front Hub/Bearing Torque Spec
Does anyone know the torque spec for the 4 bolts that mount the wheel bearing/hub assembly? 2013 XF 3.0 2WD
I also can't find the part number on these bolts, are they only available when you order the replacement assembly?
*Edit was able to find the bolts PN C2P7441 x4, still looking for the torque spec!
Thanks!
Thanks!
Received 3,274 Likes
My copy of the 2010-2011 XF 3.0D Workshop Manual says, for the front suspension: "Wheel hub and bearing assembly to wheel knuckle retaining bolt 90 Nm / 66 lb-ft".
I presume this is the correct description of the four or five bolts you are talking about, and it is 99% certain this would not have changed between the 2010 and 2013 models.
rdcsat
11-16-2007 06:20 PM
