XF Air Vent Squeak Noise
My XF far passenger side air vent squeaks once the vents hit the full close/full open position. Has this happened to you? It is kind of annoying me. When I tried to observe it further, it looked like the aluminum trim on the vent is maybe rubbing on something on the inside or the edge of the dash.
Is there a way to fix this? I only started hearing it recently and its only 1 vent so far.
Here is a video I recorded today:
Silicone lub spray with the extension tube. I would first try each side. Spray a small amount and try opening and closing it a few times. Spray a little at a time and try opening and closing it each time. The spray will not damage anything, but trial and error is the way to go. Just don't saturate anything at first if not necessary.
Damirich (06-10-2015)
So, will this spray operation help?
