XF Battery Disconnect Help
Hi guys,
I am having a few electric anomalies, AC kicking in when button is not pressed, drivers side mirror not dipping in reverse etc.
I think I read somewhere that the first port of call is a battery disconnect.
It is a 2013 XF 3.0 diesel. It seems to have 2 batteries but it's not a stop start model.
Do I need to disconnect both batteries and for how long?
Is there anything else I need to be aware of for example setting the vents to open, any codes that I will need to enter when connecting back up etc.
I would be grateful for any advice.
The only fault code I have is the temperature sensor which will be done on Friday.
Did you have to use any codes on re connection?
What was the reset procedure, why the windows?
Razwan Kazmi
04-17-2020 10:42 AM
BigCat09
12-04-2019 03:06 PM
